Discuss AECV rules on blocks of flats in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Hi
Can someone just confirm that if an upstairs flat has no AECV at the entrance or anywhere in the property for that matter then this is AR? Even when a meter cupboard is more than 6 metres away?
I have found a few threads on here with different warnings. Kirkgas says it is NCS?
Cheers
Hi
Cheers
If there is no AECV at the point of entry to a building where there is no adequate access to the primary ECV it is AR.
Advise user/responsible person.
GS(I&U)R, 9, 24
Yeah, AR. Lots of flats out there without AECV's.
Just to clarify - I assume an AECV is not required if meter and ECV housed in a standard external meter box on outside of property. AECV only required when meter/ECV housed in a locked internal or remote external meter cupboard.
Reply to AECV rules on blocks of flats in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
