Discuss Advice wanted on outdoor thermostat idea? in the Central Heating Forum area at PlumbersForums.net
Hi, my current setup is as follows (I am no expert and have worked this system out myself)
Ideal Logic combi+ 24 boiler
TRVs on rads in all rooms apart from towel radiator in main bathroom
Weather compensation sensor linked to boiler
Pretty well insulated house with little draughts and good double glazing.
I currently run this system from about October onwards through the winter without a thermostat and the house is always a comfortable temperature throughout the winter. The boiler is always on the lowest possible heat slope setting.
My concern is the amount of gas that I’m using on days where the weather is a bit warmer and the house warms by solar heating. Although no rads are on the towel rad and loop that supplies the rads is always running.
Do you think it would be beneficial to put a standard thermostat in a weatherproof box outside set to a cold weather temperature so if the outside temperature goes above a certain point the heating system turns off completely thus saving gas?
Thanks for your advice.
Mike.
If it’s weather comp it shouldn’t be on when it’s warm outside / very little
Is the curve set correctly?
Hi, thanks very much for your reply.
The boiler says heat slope 1.0 and the dial is turned as far down as it will go. It’s about 12 degrees c outside now. The burner goes off regularly before it fires up again for a short while. All rads in the house are cold atm apart from the towel rad which is on but not hot. Not sure how much gas it uses in this state but wondering with ever increasing gas prices whether I’m wasting money/environmental impact. I would not usually have the heating on today but can’t be switching it on/off constantly as the boiler is in the loft hence the outdoor thermostat idea.
You have a timer just leave it in the off ?
Do you not have an internal room thermostat connected to the boiler ?
Are you running the system from the outdoor weather compensator ?
Hi I tried a nest thermostat but found that the coolest room was one of the bedrooms. Putting the thermostat in there didn’t really work too well at keeping the house comfortable all round. I have found that using a weather compensation sensor on the outside of the house is much more effective and the only time I have a concern is with the gas usage on slightly warmer autumn days when the boiler could possibly not be running. Are there issues with trying what I suggested with the outside thermostat?
There's often a significant tlme lag of around 24 hours between the external temperature and the temperature inside a house. Internal thermostats are not designed for external use, even if they are inside a 'weather proof' box.
Reply to Advice wanted on outdoor thermostat idea? in the Central Heating Forum area at PlumbersForums.net
Hi All, Is there a way of connecting an indoor thermostat to a Viessman Vitodens 300? What thermostat is recommended? So, my home is in Sweden...
I have a heating system comprised of skirting radiators that form part of a loop from the boiler, round the house and back. Some rooms get...
Hi, I just moved into a new house and it has a Glow Worm Compact 24c combi boiler and a ESI ESRTP4RF+ programmable room thermostat and I am...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
