Discuss Advice on replacing Microbore pipes in the USA area at PlumbersForums.net
Hi I have a radiator in my kitchen which I would like to change. I was confident changing the radiator until I realised that it has 8mm Microbore piping running off through a wall and feeding another radiator.
This is pictured here
The radiator which I’m looking to install is a cast iron style one and wouldn’t look right with these pipes so I would like to change them all, is there a reason why I cannot change this 8mm piping to standard 15mm?
Uck, all that pipework needs taking out it’s painted to death and as you state way too small. I if I was you wait a month or two as it’s still cold and cold houses do not generate brownie points..then drain it down and replace properly Centralheatking
I just connected 2 elbows to existing 10mm pipework then extended 2 legs of 15mm pipework through the floor boards into vertical rad, no issues at all just cosmetically better to the eye 👍
Reply to Advice on replacing Microbore pipes in the USA area at PlumbersForums.net
