Discuss Advice on radiator installation in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi guys , just looking for some advice. Our building contractor is doing a compete replumb and we have a on a radiator he installed. it was to be wall mounted and the pipes were set to come out of the wall. It's not as clean as I thought it would be as i thought the pipework would go straight into the radiator. and just wondering if this looks correct ? And if not what do I need to tell them to do to rectify it
Simone has first fixed the pipework too low
Two options live with it
Or get them to rip the tiles off and lift the pipes
Is there any particular reason the radiator height can't be dropped to the existing pipe height?
Too low height wise and you wouldn’t be able to use the valves
That's the wrong configuration for corner valves as you say these pipes should come directly out of the wall into the valves as below
Don’t blame her, she’s a lovely girl and was just following instructions. 🙂
:D I’ve just twigged at what you meant sorry Simone
Reply to Advice on radiator installation in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Show us your fanciest radiators you've installed! We would love to see them! I love this Milano vertical radiator in the kitchen space. What do you think?
