Discuss 3/4 rubber washer Bath tap connector in the USA area at PlumbersForums.net
They look a good fit.I do as I find it’s hard to get good quality fibre washers these days and they only require a nip up and you know bath taps are never the easiest to get at
Have you used then on copper tap connectors before?Ohhh, I thought you were on about using hep washers in the hep fitting - I was going to ask “why would you use anything else?”
No I haven’t. They look a nice snug fit. Only Hep washers I’ve seen are the ones that come with the flexi’s, but they look bigger than yours.Have you used then on copper tap connectors before?
Reply to 3/4 rubber washer Bath tap connector in the USA area at PlumbersForums.net
