phillmyglass
This is my 1st post on here so hope I'm not asking things that have been asked a thousand time before. Here goes.
I am wanting to beef up the shower in the main bathroom, it's a gravity fed system to that one and has a small pump fitted to the en-suite shower, running off 15mm feeds. I am wanting both showers to be pump fed with the possability of using both at the same time?
Should I fit another small pump (the shower needs 2 bar min) on independant feeds, or fit a bigger pump and swap the 15mm feeds to 22mm? The bigger pump would use less space than 2 small ones.
Will the small cold tank in the loft be big enough to run 2 showers at once?
Can you recomend pump sizes that will do the job?
