Discuss 22mm Low pressure Check / non return valve, shower pump problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jones82
Hi
Anyone know where you can get a 22mm low pressure non-return valve, it was suggested by Grundfos to combat the pump turning on when a hot tap is used...
I've already put a U in the pipework coming off the essex boss.
The pipe work is a little strange, it comes off the top of the cylinder, the feed to the hot taps goes up to the loft, vents, runs across the loft 6m then drops down to feed the rest of the house. The shower supply is separate to this, being feed from an essex boss on the cylinder.
I'm thinking of fitting the non-return on the supply to the pump... actually wouldn't it better on the hot supply to the taps?
Reply to 22mm Low pressure Check / non return valve, shower pump problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
We have had an ongoing issue with low hot water temperatures in a school. During the recent repair of a leak, the plumbers isolated the hot...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
