Discuss 15mm isolation value to tap tail in the USA area at PlumbersForums.net
I looked around the forms but didn't find what I was looking for apologies if this has been asked here before.
My new tap tails seems to be the same size as my isolation value (15mm) what connector would I need to for it please?
I seen videos showing tap tails going straight in to isolation value but that's not happerning here.
Thank you!!
Yep need the above fitting
Hi guys so I picked the ones linked above this morning and they didn't fit. I'm guessing now the tap tails are little different to standard ones. Having looked at the Amazon page my package should have included " 2x 3/8 to 1/2 adapter"
I'm not sure what that means but is thia what I needed to make the connection? I have emailed the seller but now have to wait, just wanted to make sure as kinda desperate currently and don't mind picking it up from the local parts store again. Thanks a million.
Just take the nut and the olive off the end which the arrow is pointing to, file the end of the valve so you have a decent landing edge and fasten the hose to the valve, Make sure landing edge is level. You can buy a valve with the landing edge already machined.
It’s 3/8 not 1/2”
Reply to 15mm isolation value to tap tail in the USA area at PlumbersForums.net
