Discuss My new kitchen mono tap in the UK Plumbers Forums area at PlumbersForums.net
Plumber had fitted a new mono kitchen tap. The hot water takes ages to get hot if at all. The on lever hadn’t much turn on it and it’s at full throttle. Also when I point tap to bowl with fairy liquid in, it doesn’t have enough power to make bubbles
Do you have a gravity cylinder eg copper ?
So should be equal pressures within reason
Isolation valve party close ?
Reply to My new kitchen mono tap in the UK Plumbers Forums area at PlumbersForums.net
