Discuss upcoming job Back boiler replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
Hello Lads,
as above I am having an upcoming boiler conversion. I am a little bit concerned about few things. First of all it is a council flat which makes the installation much harder. Furthermore I am having just concrete walls and floors which is really hard to run pipe works throughout the place towards the new boiler place. I am also concerned about the gas pipe because the gas meter downstream has a massive steel pipe going straight down into the floor and T's off before that into the concrete wall. I was wondering if anyone knows if that could be a supply for all flats?
The size i would say is about 40 mm steel pipe. I also struggle to find a way to run a new gas pipe towards the boiler it is in a weird position. The good thing is that the flat is at the top floor which means I could use the loft space to run my central heating pipes from the cylinder cupboard towards the new boiler location which will be either in the kitchen next to the sink or in the food storage corner behind the fridge. i was thinking to install the boiler in the cylinder cupboard but i believe I will not manage to do the vertical flue through the roof accordingly.
you can see my attachments to get a better idea of the layout of the property.
Perhaps either one of you came across a similar installation and layout and could give me some helpful tips to make my life easier.
I am a little worried that I am facing some problems and therefore I am on here again to pick all your brains to get as much information from other experienced engineers.
Here are the attachments
Boiler on external wall flue straight out, pipes run through loft space . Good bunch of lads can crash this out in few hours easy money.
If it was that easy I wouldn’t come on here. :) the gas pipe for example isn’t that easy to get to the right location. I will definitely use the loft space to run my ch pipe from the cupboard to the new boiler location. In the loft is mains supply which I will use to connect onto the bathroom supply and hot water will be taken from the cupboard too.
No chance I can go through the loft due the bricks above. If I found a way to do so, would I be allowed as it is not her loft but the housing associations. Any particular rules I have to follow?
You can’t work on the incoming gas pipe only after the meter.
I’m guessing the steel pipe is the incoming?
Reply to upcoming job Back boiler replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need someone to replace my boiler, I am thinking to get an Intergas HRE 24 SB. Our current boiler (and old Ideal) is in the kitchen, and we...
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up...
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
  • Locked
Hi, I recently fitted a new central heating circuit and ran hot and cold to the bathroom and kitchen in my property (I was a CORGI registered...
