Discuss 1 1/4" condense lagging? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
Hi all.
Whats the the best insulation for external condense? Where do I get it from?
Thanks.
If external it needs to be closed cell lagging i.e. armourflex I'd imagine your merchants should stock it or bat least be able to get it for you.
I can see it on the website. Armaflex class O.
Just concerned about the 2 1/2 metres of 32mm going to the soak away freezing up. Any other precaution I could take?
I really need some suggestions on this folks. Would like a secondary precaution to stop the freezing. I've heard air gaps mentioned but surely if the air gap is outside then that's destined to freeze?
As above aflex and you could look at trace heating if you want
I'm going to pick up the lagging now. Unsure whether it's enough.
Never used one before mate?
Looks a bit like twin and earth and artic cable simple to do just either wrap in spiral (if too long) or put where water runs are eg bottom of pipe
Lol. I wouldn't even touch this job if it weren't a mate lol.
Lol just drove through a local estate and nearly every one comes out in 21.5" and into 1 1/4" with an air gap with no insulation
Less need to insulate if your upsizing to waste pipe size...
Reply to 1 1/4" condense lagging? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
