Discuss Bath to shower waste and siphon danger? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
2 things please if I may:
Trying to work out wastes for a bathroom fit. Shower will have a 40mm pipe run just under 3m into hopper. Considering teeing or angling a bath waste into this on the distal half. Would the bath definitely, maybe or not be likely to siphon the shower trap? Wondering how necessary it may be to run bath waste separately.
Then, depending the level i set the bath, the bath trap can either be above floor, disappear below floor, or be below floor. Should it be accessible? That would seem logical, but what makes me wonder is that shower traps are not. Not without taking up the tray and the floor, which doesnt happen much otherwise there would be another way to do them presumably. Are bath traps different for any reason?
Thank you for taking the time to read.
seperate wastes needed. bath trap will be above the floor level. shower traps can be cleaned out from above, bath traps may need to be removed to clean out.
make sure you use a lipped tray or a classi seal.
Thanks for the pointer on the classi seal!
For the bath, was looking at using a bottle trap like this...
https://www.NoLinkingToThis/p/mcalp...mm/21158#product_additional_details_container
Seems similar to most shower traps, so could be cleaned from above like a shower trap, so wouldnt then need access, or is it still best practice to have access? Are there other things that im not bearing in mind?
Yes it could be, but wanted to set it lower so its easier to get in and out of. Suprised really this isnt more common, unless there is a good reason against it.
Reply to Bath to shower waste and siphon danger? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Total refit of of bathroom. I've got a 40mm waste from the shower running beneath the floorboards to an external wall and out. Just above where the pipe exits is where the obvious place for the bath waste to exit as well. Should I use separate waste pipes for the bath and the shower or can the...
2K
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning towards the waste end though. The shower tray is pushed underneath the tiles. My mate did the tiling and I now realise that we should have put the shower...
Hi, As per title we have a regular smell from the shower trap. Clean the trap twice a week, had a cleaning rod down the shower waste pipe and no blockage. Used several different drain cleaners over time but smell returns (not always but often enough to be annoying). Seems to coincide with...
Hi, I have a few issues with my bath drainage and leaking. The first issue is that the near corner of the bath by the taps is sloped downwards meaning that it pools in the corner and quickly starts leaking through gaps in the shower screen onto the floor rather than into the bath. The rest of...
