Discuss Working Pressure at meter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
barronbathrooms
Fitted a Worcester greenstar 24i j for brother today. working pressure at meter was 23.5mb. it was a metric ETM meter how can i get an accurate gas rate with these meter? will the high W / P effect the H O or will the zero governer prevent this?
What other appliances if any,were in the house? Have you got a flue gas analyser to commission the boiler?
a working pressure of 23.5mb is to high. should be 21mb + or - 2mb.
re checked working pressure 21mb manometer not set right! school boy error! had borrow fga to check a/g ratio as couldn't get accurate gas rate on metric etm meter how do you gas rate appliences with these meters?
I think the FGA would provide a more dependable indication of correct operating conditions whereas the gas rate is a much coarser indicator.
are you talking about the meter that you have to keep pressing the button to refresh the reading? if so there is a technical bulletin about gas rating with these meters. They are not great.
Reply to Working Pressure at meter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON...
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
1K
