Discuss work/task light in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Captain cool
I'm looking to get a new 240v work light if anyone can make any recommendations.
it has to be LED as I don't want to be messing about with bulbs.
I have a rechargeable LED 5w that is handy in lofts etc. Like this one;
It is a bit flimsy and it's power lead is a thin a bell wire.
I want ant something I can set up in a loft or airing cupboard that I'm going to be in all day.
I don't have one yet but Screwfix have a range of LED worklights atm...some 240v some rechargeable.
Make sure you pick enough lumens for the job...
10/11watt LED = approx 75W incand
24w LED = approx 125w incand
http://www.NoLinkingToThis/c/electrical-lighting/portable-lighting/cat8340010
I've got one of these:
http://www.NoLinkingToThis/p/defender-e709150-2d-work-light-38w-230v/78401
It's brilliant. Seriously bright, weighs next to nothing so you can hang it up with a bungee or a twist of wire. Replaceable bulb but I've had mine 4 or 5 years and not burnt out yet.
I have a massive led torch that works of a motorcycle battery. It was expensive but will stay illuminated for 12 hours on full power
You and a light with a cre led, not one with lots of smaller leds. I have a 2000lum 18v Ryobi hybrid light from the USA which can also be plugged into the mains although I've never bothered to sort a lead out for it.
The 240v screwfix ones are good for the money, sparks on site has got one and it's good.
Reply to work/task light in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
