  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss work/task light in the Plumbing Tools area at UKPlumbersForums.co.uk.
  1. Captain cool
    Captain cool New Member
    I'm looking to get a new 240v work light if anyone can make any recommendations.
    it has to be LED as I don't want to be messing about with bulbs.
    I have a rechargeable LED 5w that is handy in lofts etc. Like this one;
    It is a bit flimsy and it's power lead is a thin a bell wire.
    I want ant something I can set up in a loft or airing cupboard that I'm going to be in all day.
  2. gmartine
    gmartine GSR
  3. Masood
    Masood Guest
  4. newcastle phill
    newcastle phill Guest
    I have a massive led torch that works of a motorcycle battery. It was expensive but will stay illuminated for 12 hours on full power
  5. tolly
    tolly Plumber
  6. gmartine
    gmartine GSR
    ^^ 4000 lumens is projector bright.
  7. tolly
    tolly Plumber
    It is very bright but id take most quoted lumen figures with a pinch of salt.
  8. newcastle phill
    Its a nightsearcher 750[​IMG]
    • Like Like x 1
  9. AWheating
    AWheating Trusted Plumber GSR
    You and a light with a cre led, not one with lots of smaller leds. I have a 2000lum 18v Ryobi hybrid light from the USA which can also be plugged into the mains although I've never bothered to sort a lead out for it.
    The 240v screwfix ones are good for the money, sparks on site has got one and it's good.
Loading...
Similar Threads - task light Forum Date
Ifrogz portable battery and flashlight 9000mah battery. For Sale & Wanted Jul 8, 2017
Slight noise/growl/vibration from taps Plumbing Forum May 11, 2017
Replacing a Triton Enlight 2 New Member Introductions Apr 21, 2017
Slight water leak, don't know what the part is called! Plumbing Forum Apr 15, 2017
Potterton Suprima. Runs for few hours then shuts down, red light. Plumbers Arms Mar 8, 2017
Baxi Solo HE 18 - won't light! Gas Safe Registered Plumbers Only Feb 28, 2017
Main Mersey Water Heater not lighting on hot water Central Heating Forum Feb 23, 2017
