Discuss Worcester Greenstar 30Si Gas Valve changeover in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Spreck
Hi Guys,
has as anyone had to do a conversion from the old gas valve on a Worcester Greenstar 30Si to the new one they are supplying now?
it looks like it might be an a*se? Seems it comes ready for 28kw and you need to faff to settle the Co/Co2 ratio change over some lovely plastic connections to enable changeover ((I'm not a lover of plastic parts in boilers although the norm now damn cost reductions! (Not passed on to us!!!))
Ratio I can sort but looking for any tips tricks angles of insertion? Only clean posts I know it's tempting!
Ta
Ok update...
if you have access to the left hand side of the boiler it would be a lot easier to get the valve fixing screws in and out. If not out with the old style condense trap ,short PZ1 required as condense mounting riveted! Bit tight on space to get the new valve connection onto the pushfit so I'd do it first in hindsight easier to make the rubber hose connection and grab clip in after.
if no access on left allow yourself another half hour of swearing at grazed knuckles when pricing!
hope this helps in the future.
spreck
Reply to Worcester Greenstar 30Si Gas Valve changeover in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am a retired gas engineer. Corgi and Domestic Electrics + Building Surveyor. I have a Greenstar CDI 35kw that I fitted in my own home 15 years...
T
  • Locked
Hi guys I'm a gas safe engineer and am currently struggling with a breakdown. I was called to the property to fit a new filling loop (remove...
10K
Kev the gas
K
  • Locked
Hi all I am a qualified electrical and mechanical engineer but not gas safe so used an 'old school' but very clever plumber for the gas part of...
6K
squarepeg
C
  • Locked
Hi I have followed helpful guides on this forum for topping up the worcester greenstar 24i - i now know where to insert and turn the key to the...
9K
stevejordan
M
  • Locked
Hi guys, First post. I have a Worcester greenstar junior 26cdi - something like that. Anyway, a few times in this winter and last it has packed...
16K
brightongoose
B
