Discuss Worcester green star 30si fault in the Central Heating Forum area at PlumbersForums.net
We have a Worcester green star 30si boiler
Hot water is fine.
Ch temp is set at 70 degrees but boiler heats to 68 quite fast then takes ages to heat to 72 when it finally pumps round system,
Seems to be on constant low burn?
Tbh should be max 65 c for heating
That’s normal tbh won’t go into max burn on ch
Reply to Worcester green star 30si fault in the Central Heating Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
