Discuss worcester bosch si 30 combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi, i am looking for help regarding a worcester bosch condensing boiler,all was fine untill today when all of a sudden the blue light went out and no power,checked main fuse this is ok,checked and replaced the other 3 fuses in the electrics behind timer ,still no power any ideas or tips would be appreciated.
Have you checked there is electric at the plug
Try checking your house fuse board
hi, yes i have checked all the obvious things ,plugs sockets etc but cant get power to the blue light,are there any buttons to press or procedures to follow,
Only the on button. It's a latching button on the left
That's not a sarcastic answer either
I think you need an engineer
Place a post on the need a plumber forum
Reply to worcester bosch si 30 combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester Bosch Greenstar 30Si combi boiler, the analog clock has stopped and the On-Timer-Off switch only works on Timer setting...
W
My Worcester Combi Boiler is not working, instead the display flashes on and off repeatedly, as shown in <a href=" View...
J
Hello, I have a Bosch 35CDi, and today found all the lights flashing on the front. Normally I can reset the boiler, but this did not work. There...
Deleted member 120897
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
Hi all, I am not sure whether anyone ever saw this issue.... My Worcester Bosch boiler was installed last year August, since then I found the...
2K
