Discuss Worcester Boiler not Firing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jaymis
I have a 3 year old Worcester Greenstar 24ri condensing boiler.
The fuse blew a couple of times and later found out there was a water leak from magnaclean.
Our magnaclean sits under the boiler cupboard with Honeywell controllers under it.
We have today replaced rubber ring in magnaclean causing leak but now the boiler won't fire up.
Unfortunately the way the magnaclean is position directly under boiler cupboard it's difficult to
remove the air from top of magnaclean.
The temperature stat keeps saying low battery but the its fine.
The boiler was working until magnaclean was cleaned.
The hot water and heating not working. The boiler fires up for 2mins and dies.
I am hoping its something simple but not sure what else to check.
Any ideas ?
Have you opened the isolation valves back up? If not sounds like air in Magneclean or somewhere else in the system.
Yes the isolation valves were opened back up after cleaning Magnaclean.
I can't get to the top of the magnaclean to remove air as it is located under a boiler cupboard.
Is there any other way to remove air ?
These stupid autocorrect or suggestion things on tablets and phones making me mad! :(
Unvented*
Reply to Worcester Boiler not Firing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
Experiencing an issue with a Worcester Greenstar 21i conventional boiler if anyone could help! I have previously installed a Tado smart controls...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
Hi, Can I pick your brains? My boiler is often reluctant to start, sometimes it does, sometimes it seems that it will if the demand is from the...
