Discuss Worcester 40 CDI conventional Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Danv44444
Hi Guys, I got called to look at the above boiler last week because the boiler would not stay ignited. The Flame kept fluctuating then eventually went to lockout. I phoned Worcester technical and tested evrything as they said but still couldnt find anything to fix it.
In the end the customer paid for worcster to come out and fix it for £250. The customer isnt very technical put said the worcester guy said it was something simple.
Have any of you guys ever come across this with worcesters before. I checked the gas valve, fan, Flue and cleaned the heat exchanger.
Any help for future reference would be appreicated.
how old?
Did it throw an F code or EA?
Hi Vern, Installed in 2007 and fault code fo. it also flased up ea
Guys, open forum!
Can you please both PM Mr Doberman with your gsr details so topics like this can be discussed in the gsr engineers private forum?
You'll also gain access to the plumbers arms where much quaffing and merriment goes on!
ta muchly!
Guys, open forum!
ta muchly!
Will do pal
hi Croppie, I am in the gsr forum already. Sorry i thought this post was in there??? I sent a message off a while ago but cant get in the plumbers in arms?
Can you pm him again please Danv? if he added you to both your name would go red and you'd have Gas Safe Registered under your picture too.
Cheers mate.
Is the the correct message address " Mr Doberman". ? Not being funny just want to be sure?
Reply to Worcester 40 CDI conventional Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
1K
Hi All, I have a Worcester Danesmoor 20/25 oil boiler which is causing me lots of heartache and grief. About 3 months ago it locked out and...
2K
Hello, I've previously had an issue with my boiler pressure getting too high with the central heating on and needing a reset. I had a gas plumber...
2K
Is there anyone out there who has come across this problem. Our boiler locked out so pressed the reset button and it seemed that all was fine. Red...
2K
Hey. Fairly new to oil. Serviced above boiler Last week. All working fine but now had customer call to say it keeps going to lockout. Been and...
5K
