Discuss wiring in two thermostats in the Plumbing Jobs | The Job-board area at PlumbersForums.net
g60rge
so we have a combi system, old vaillant ecotec plus.
installing a single zone john guest wireless kit
current room stat wired as per normal
ugh will have a zone valve and will only work when normal heating is on
how is the new stat wired in, can you have it parallel with the current one in connections 3 and 4?
You'll need to zone both existing and UFH individually bring switch live from both back to 4 from memory. That's how i've always done them
anyone else?
anyone else what?
wire it as an s plan heating as (heating zone) under floor as (hot water) cylinder stat = room stat
Reply to wiring in two thermostats in the Plumbing Jobs | The Job-board area at PlumbersForums.net
