Discuss window behind shower enclosure?? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Jennie
Hi all,
I've got a new customer who wants a bathroom fitting. This would include a shower tray, and shower panel being situated partly across a window. It's far from ideal, but they've already bought the shower tray/panel/etc. It's a tiny bathroom, with no options for changing the layout.
I'm thinking to do the tiling, fit the tray, and then the panel - as normal. But only using part of the wall profile, up to the window ledge. And then using a shower panel bracket to secure the top edge of the shower panel to the adjacent wall.
And then getting a glazier in to fit a rectangle of safety glass across where the wall should be, and making sure it's sealed and watertight.
What do you all reckon?
Thanks for your advice
Jennie
Reply to window behind shower enclosure?? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes sunk into wall behind bath. Walls have fresh tiles. Have realised as about to fit shower these pipes one is set higher than the other. If you fit a...
