Discuss Will this bottle trap fit this basin NEWBIE in the USA area at PlumbersForums.net
It’s the waste it (the trap) fits onto, so providing it’s standard size (1 and 1/4”) then should be good to go.
This is the popup waste I bought
It says this in the description
- Fits any standard 1.5" (38mm) opening installation.
But in the dimensions it says
PRODUCT WIDTH: 2.44" (62mm)
Do you think this will be ok, also will the bottle trap pipe be too long or is it adjustable
Ok, so your 1st photo shows it comes supplied with a piece of wastepipe, and if you click the information it states 32mm (which is commonly referred to as 1 and 1/4”). The second one is just a waste and the trap will screw to that one, so probably best with the second one to avoid confusion.
It doesn’t matter maybe for the waste and trap, but bear in mind if you source bits and pieces from all over the place you will end up with seven different “brushed golds” (If you buy seven things, obviously!)
At the risk of shattering your dreams, I have some apprehension when I see someone considering something of an unknown manufacturer from the supplier to whose website you have linked. I would stick to known brands of sanitaryware, personally speaking.
I think you should ask who the manufacturer of that basin is, get it in writing, and if it isn't a brand well-known and respected on this forum, I would be inclined to look elsewhere, especially as that basin is not even particularly inexpensive.
Reply to Will this bottle trap fit this basin NEWBIE in the USA area at PlumbersForums.net
Hello, I've got this reducer FloPlast Overflow Waste Reducer White 32mm -...
Hi everyone, I am planning to renovate my small en-suite and to replace the current standard basin with a counter basin. I have some doubts...
3K
Hoping for some advice on the use of AAVs while plumbing in my new bathroom. There is a sketch of the waste layout in the link below. All of the...
2K
Stephen44uk
Looking to fit wall hung basin with a bottle trap fitting going into the wall on the wall below. I need to run a waste pipe between the waste...
The Waste is slightly higher than the trap, I've been advised to use the flexi fitting but it leaks and doesn't look strong enough especially as...
