Discuss will the joists and flooring take the weight of a corner bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Tony Watling
I have been asked to fit a corner bath for a client but I am not sure if the joist in hes bathroom will be man enough?
I am investegateing the sizes but I think they will be about 3 x 2.
yeh, i think it will be perfectly fine, go for it
disclamier: fuzzy
What size is the bath and what is the water capacity? The very fact that its in the corner is a help as its tight to the wall.
This will tell you what they SHOULD be:
tech2.html
If they are under sized ot r you are unsure you could always coach bolt steel plates through or double up the joists
mate if in doubt run extra timbers under the legs like ud do on a chip bourd floor or 18mm ply and spread the load floor joists are normally
5 by 2 at the least if your close to the wall its more stable as well
your havin a laugh.
is the bath going in the shed?.
no way will joists be done in 3x2!!!
stand 4 people in the corner and tell them to jump, if it takes that then it will take a bath. lath some timbers accross the top to make more rigid.
its the same as putting a elephant on a tree branch and expecting it to hold
thanks for all your comments I will see in due coarse the actual joist sizes and take things from there.
Ive worked on a few old terraced houses in Derby where the joists were 3x2 in the bathroom we had to surface mount five pipes along the walls, it looked realllllly nice.
Reply to will the joists and flooring take the weight of a corner bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Hi All, I am looking to take my bath out and fit a shower. Regards to tanking. Is it ok to just seal everything with plastic rather than just...
