Discuss Why Can't I get hot water in my bathroom sinks. in the USA area at PlumbersForums.net
Hi all I am currently experiencing a perplexing problem. I seem to have hot water everywhere in my house except the bathroom sinks. Kitchen sink is fine, showers and jetted tub is also fine. Its a 2.5 bath home, one bath room has double sinks. This bathroom uses "Y" connectors to supply hot and cold water to both sinks. When I turn on the hot water whatever hot water that is in the line because of our triple digit temps goes cold. Every faucet beside the jetted tub is a single faucet, but there is a hot and cold shutoff valve for every bathroom. Is this a job for a licensed plumber or is this something I can fix myself? Any help will be greatly appreciated.
That’s a strange one tbh would need someone looking in front of it to figure it out
So the water starts hot but then runs cold?
Instantaneous water heater in basement?
Could be a dodgy mixer or failed double check valve allowing cold water back into the hot pipes.
Thanks, I was trying to avoid that, but I guess I don't have a choice.
[automerge]1597272316[/automerge]
Yes, it starts out hot because of how it is here then runs cold. No basement and regular water heater. Where in the line would the check valve be installed? How likely is it for the mixers on three different sinks go out at the same time?
Do you know if there fed from all the same pipe / tee off ?
Reply to Why Can't I get hot water in my bathroom sinks. in the USA area at PlumbersForums.net
Where and how does the water supply work and is there only one rising main pipe and where is it usually located? I am top floor flat, mains fed...
Hi everyone, Is this set up correct: Attic stop valve turns off the cold water to my bathroom (I think it is the rising main in the attic which...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Hi, Just had a new bathroom fitted and have a pathetic flow of hot water from the sink tap. It wasn't great before. I can't get hold of a plumber...
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom...
