Discuss Bathroom hot water sink tap. Low flow in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Just had a new bathroom fitted and have a pathetic flow of hot water from the sink tap. It wasn't great before. I can't get hold of a plumber, but any ideas as to what this might be? I also noticed that the pipes that feed the hot tap go into the loft? I know nothing about plumbing, but is this usual?
Do you have a water cistern in the loft that feeds a hot water cylinder?
Did you supply the taps?
Its highly likely that you've got a low pressure gravity system with a high pressure tap. Failing that I've had debris get into the isolation valves which slow it down a lot while looking like its just a gravity issue.
Reply to Bathroom hot water sink tap. Low flow in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Sonya K
