Discuss Which Gate Valve will turn off cold water to the taps? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I think we have an indirect hot water cylinder, we are trying to replace a sink. However there are no isolation valves on the in-between the taps and the piping. Is there a way to turn off the cold water flow to the taps, without turning off the main water supply incoming to house ? I have found the gate valve to turn off the outgoing hot water.
But not sure where this pipe goes it to, I know it's cold water . I've tried isolating it but seems to have no effect.
Are you sure the taps arnt off the mains as normally basins are due to drinking water and brushing your teeth
Reply to Which Gate Valve will turn off cold water to the taps? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I have a problem with noise and vibrations from my shower when i first turn it on. The problem lasts for about 30 seconds after the shower is...
Hi all. My hot water feed for my shower is on the left and the cold is on the right. My understanding is that this is correct and this is also...
Hi all. My hot supply for my shower is on the left and my cold feed is on the right. My understanding is that this is correct and this is also...
Saneal
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
I purchased 2x 1/2” tap gland for my basin because the hot one was faulty. I had to turn the stopcock of in the kitchen. I also had to turn...
