M
marsaday
From the pics you can see i have 2 new pipes coming out of the wall for my shower and sink.
The best soultion is to run them into the downpipe at the side of the building. This means reducing the downpipe where the bend from the gutter hits it and fitting a hopper.
The gutter extension will sit on this and i will bring the 2 waste pipes into here as well.
The second solution is to extend the current hopper using new pipe and another hopper. The only problem will be the fan gets in the way, as will the light and gas pipe.
Any other ideas on which is best soultion. The first one will be the cheapest as all i need to buy is the hopper and it keeps away from all the problems. The only downside is maybe having to get a plastic gutter extension instead of using the current cast one (too heavy if sitting into a hopper ?)
Both downpipes run into the rain water system and not foul water.
