Discuss Where should condenser drain on condensing boiler terminate? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
fgbfox
Hi All,
We had a new condensing boiler (heating system) fitted in the loft earlier this year.
On showing a friend the new installation, he asked why the condenser outlet drain was plumbed into the stack pipe (from the w.c.) that passes through loft space and out above the roof. He seemed to think this was not a good thing.
Any ideas if this is a problem and where should condenser drain pipe be terminated?
Thanks for any help.
:confused:
The condenser drain is fitted to a waste pipe to go down the drain so if its in to the soil stack i don't see a problem
Thanks for a very swift reply.
I'm reassured you do not see this as a problem. So, thanks again for your helpful reply.
Reply to Where should condenser drain on condensing boiler terminate? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Engineer has installed several boilers for me. All the condensate pipes have been connected externally into soil stack or rain water downpipe. In...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady...
Following a first-floor bathroom remodel done poorly by a plumber in our house a couple of years ago I have stripped everything out and I'm...
1K
Deleted member 120897
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also...
