Discuss where is the condensate pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a worster bosch combi boiler.
When I just use hot water everything is fine. If I turn the central heating on the boiler bubbles like crazy and tries to light with a booming noise.
It then fails and turns on the reset.
I have searched through various areas including this site and come to the conclusion the condensate is blocked.
Could this be the white plastic pipe that comes out of the bottom of the boiler and goes out through the wall?
I can't separate the joints, I assume it has been glued together.
It is possible it is frozen just outside the house.
If it is this pipe might just pulling it apart solve the problem and let the condensate go into a bowl in the room?
Too late I have managed to get the pipe off the bottom of the small tank, there was a small spray of water and now the system is working perfectly. I just have to, somehow, clear the pipe. I think the best way as It goes through a few bends is to cut it just inside the wall and clear it then get a double female for the plastic pipe.
And now you have the possibility of carbon monoxide entering the property from the boilers condense trap. Please turn the boiler off and get an engineer out to make sure that it is done properly.
Reply to where is the condensate pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Engineer has installed several boilers for me. All the condensate pipes have been connected externally into soil stack or rain water downpipe. In each case he just drilled a hole in the pipe, and stuck the condensate in the side, smeared glue everywhere. No boss, or branch. Is this allowed, is...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing with it as a matter of course. If I'm wrong can someone let me know and I'll shift it to a better place.] I have a condensing boiler installation...
I have a CH boiler installation with a nice simple vertical condensate drain, down and out through the wall to a pipe outside. All is as it should be but I'm fitting an upgraded external pipe setup to include insulation. The inner 22mm pipe mates with the 32mm pipe just inside the house. It...
Our boiler is in the loft and I encountered a leak in a roof above our side extension store room which has transpired to be from the boiler condensate pipe. It was cracked at an elbow so the plumber we use has replaced this and hopefully all will be well with that joint. This later prompted me...
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old people. Out here competence and integrity is harder to come by in a worker, in fact it's hard to find workers at all where we are in the countryside...
