Discuss Where can i get an imperial stopcock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
ARMIGER
I need to replace a 3/4"-1/2" stopcock. A 22mm stopcock will not fit onto the existing old plastic pipe. I cannot find anyone who stocks this old imperial size. Any idea where I can get one or how can I overcome this problem.
Hi. Try this site, [DLMURL="http://www.plasson.co.uk/main.asp?cat=site&sel_nav1=18"]Plasson UK[/DLMURL] a phone call might get you a local stockist. The supply adapter kits for most situations, There a bit bulky but ok if you have the room and the aesthetics are not a problem. Good luck
the pipe is black. a 22mm stopcock is too big. The existing stopcock is 3/4", I tried a conversion olive but it won't fit over the black pipe.
Any help would be appreciated. Thanks.
Reply to Where can i get an imperial stopcock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
