Discuss Where can I find a 4 way 21.5mm PVC joint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dont think you can get one tbh, cant see why you would need to, be allowed to join four warning or condense pipes together.
I know that fitting to be called a cross T, pipe centre is the best place or BSS
I have seen cross tees in 32mm, 40mm. 50mm and 110mm, but not in 21.5mm. What would you use one for?
But in any event, a cross tee is still essentially only in two planes, like this:
whereas the OP was looking for a 3 plane tee - like a corner tee but with an additional branch
Reply to Where can I find a 4 way 21.5mm PVC joint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
