Discuss What pipe to purchase in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jser63
Hi all,
I want to put water to the bottom of my garden and am looking at purchasing MDPE pipe to put underground from my house to the shed. I have a 22mm copper pipe in the house I want to attach it to, do I purchase a 20mm or 25mm MDPE pipe to attach to it. The distance if it matters to the shed is 50m. Thanks. J
if its just for watering the garden 20mm will be fine
Hi ShaunCorbs, No it is for a shower, toilet and sink. Regards. J
As above not much difference price wise go for 25mm
To conform to the water regulations, it should be buried to a depth of no less that 750mm but no deeper than 1350mm. It should be 350mm away from other services and at least a meter away from trees.
If you'd like to know more about your responsibilities when undertaking this type of work, you can find out all you need here:https://www.wras.co.uk/
Reply to What pipe to purchase in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
