Discuss what kind of pipe is this - water leak in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all
hope you are all well .
Is the pipe in the photos lead or steel ?
I suspect its leaking further down (water) as there is a puddle and I could hear running water until i turn the water off in the street
thanks!
Steel that might be a gas pipe so be careful digging down
If this is in the UK, I'm fairly sure it's not a water supply pipe but not because of its material. It's is not buried deep enough with respect to the surrounding ground level and would freeze during the winter.
Like @ShaunCorbs, I'd err on the side of caution and assume it's gas until further investigation proves otherwise.
Reply to what kind of pipe is this - water leak in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
