- Messages
- 94
Is there such a thing as "wear and tear" causing joints in a new heating installation to leak within two years? As in infrequent heating and cooling of the water in the pipes causing expansion and contraction of joints?
Discuss Wear And Tear Causing Leaks? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I hope the leaking lid wasn’t yoursTf1 is a good unit ...I designed part of it
I was trying to break it gentlyand the valves also the plastic threads failing in whole rubbish unit
No way , Api 20o6 only ever designed the in and out portI hope the leaking lid wasn’t yours
so it is partly one of yoursNo way , Api 20o6 only ever designed the in and out port
ports to this type of mag unit,
we did a few in the late 90's
and maybe advised on the magnets....and the stainers
for non mag stuff. Basically
designing these things was simple ...a bit like tuning an engine...high performance petrol unit which we were familiar with , but it was fun
centralheatking
Here is an photo of the main leak, in a cupboard which is not opened often. There are photos of the main part of the system 80 metres away in my thread "Pressure drops when 650 litre buffer tank is filled with water but no drop with air" of Ictober 2016.
What a mess, chkingThe photo of the TF1 above was taken on 04 Sep 2018.
This photo was taken on 08Aug2016 during the period of the failed investigation into the loss of pressure. See the TF1 area in question on the left. The area below the topmost red valve looks suspiciously brown?
Reply to Wear And Tear Causing Leaks? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
