- Messages
- 94
Is there such a thing as "wear and tear" causing joints in a new heating installation to leak within two years? As in infrequent heating and cooling of the water in the pipes causing expansion and contraction of joints?
Discuss Wear And Tear Causing Leaks? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
uck chking...but thats being growing for a long time, do youHere is an photo of the main leak, in a cupboard which is not opened often. There are photos of the main part of the system 80 metres away in my thread "Pressure drops when 650 litre buffer tank is filled with water but no drop with air" of Ictober 2016.
I serviced that TF1 myself once and was found to be clean. It was also serviced annually by the supplier/installer/plumber.
The brown could be a result of the buffer tank being emptied filled heated emptied multiple times over serveral weeks, obviously having lost the inhibitor in the process. The inhibitor has been replenished twice since then as the saga unfolded.
Reply to Wear And Tear Causing Leaks? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
