Discuss Ways to prevent slip coupler slipping down a vertical copper pipe while soldering? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Re: Ways to prevent slip coupler slipping down a vertical copper pipe while soldering
pinch the end of one of the pipes slightly
The side pressure of the pipes usually holds it in place.
I make a pencil mark then I slightly oval the tube with grips before slipping the coupling on.
when you put the coupling on after, it stays...
Give it a little squeeze!!
Start by heating the bottom pipe, it should expand and tighten
You can borrow my pipe slice if you want, it squeezes the pipe so badly I can't get conex nuts on the buggers without reforming it with my pump pliers ;)
Pipe slice under coupler or use your grips to slightly pinch the coupler on to the pipe
use powerflux. that'll lock the fitting in place :)
As others have said, I go for giving the fitting a gentle pinch so it still slips but only when you are actually sliding it into place.
Whack it gently with a centre punch !
Don't use a slip coupler, cheeze!!!
Sounds like my old (brand new) Nerrad pipe slice, it would spiral so bad I could have fit mic straight onto copper pipe!
Reply to Ways to prevent slip coupler slipping down a vertical copper pipe while soldering? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
