Discuss Washing Machine tripping electrics. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Rompa
Hi. I have a general query regarding my Hotpoint WM.
For the past few weeks it has been tripping the electrics as soon as it starts a cycle. It fills up perfectly but after a spew rotations of the drum the electric trips.
This does not happen on the rinse or spin cycle.
After reading a little online I'm starting to think it may be the heater element.
So, this evening I've taken the rear cover off to do a little troubleshooting. First I disconnected the temperature sensor but it still tripped. I then reconnected the sensor and disconnected the two plugs that attach to the heater element. I isolated them both and started a regular wash cycle.
No tripping of the electrics.
Am I correct in believing that the problem is very likely to be the element? I don't want to spend £60 on a new one if it could be something else... but all appears to be functioning correctly without the element attached.
Thanks for any advice:)
Gary
Waste of time - not worth the expense.
Simply replace element every 2 to 5 years or however long it takes to pop - cost under a tenner.
Calgon - crazy expensive
Water softner - see above
Elements can go anyway regardless. Something that costs under a tenner isn't going to last a lifetime anyway
What about all the other components connected to water supply on the appliance ie pumps, ntcs,solenoids, jet systems ectc
Yes but most customers are not as savy so it would defs cost more than a Tenner... If a customer can afford then I would always recommend a softener, longer life for all appliances, taps & bathrooms that aren't covered in scale & scum
What a load of cods wallop.
Only 3 solenoids on a washer.
1 mainwash and 1 fabsoft and 1 prewash.
All on inlet side. No scale at all. Never in my years and tears of fixing all brands have i ever replaced a scaled up solenoid valve - it just doesnt happen.
Especially now they are all cold fill only and have been for years [emoji12]
So please enlighten me again. How does scale form on a cold fill inlet solenoid
Reply to Washing Machine tripping electrics. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
