Discuss Washing Machine tripping electrics. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Rompa
Hi. I have a general query regarding my Hotpoint WM.
For the past few weeks it has been tripping the electrics as soon as it starts a cycle. It fills up perfectly but after a spew rotations of the drum the electric trips.
This does not happen on the rinse or spin cycle.
After reading a little online I'm starting to think it may be the heater element.
So, this evening I've taken the rear cover off to do a little troubleshooting. First I disconnected the temperature sensor but it still tripped. I then reconnected the sensor and disconnected the two plugs that attach to the heater element. I isolated them both and started a regular wash cycle.
No tripping of the electrics.
Am I correct in believing that the problem is very likely to be the element? I don't want to spend £60 on a new one if it could be something else... but all appears to be functioning correctly without the element attached.
Thanks for any advice:)
Gary
Test the resistance across the heating element and compare it to manufacturers data. If it's tripping the rcd not the circuit protective device also check resistance to earth.
Disclaimer .........Only if your competent to do these tests of course. Welcome to the forum.
Thanks for the reply. It's tripping the one circled in red. It's labelled RCCB.
I'm quite competent and happy to explore myself. Is it tripping the RCD and how would I go about checking the earth? I've an old analogue meter... but could always get a digital one if that's any better?
Cheers! I've got my sparky dad popping around just to check the earth as mentioned in the previous reply... but from research I'm thinking the element too. Well, it could also be the thermo as it's built into the element. Either way, I should know more soon.
Many thanks for your help!
Gary
New heater ordered and arriving in the AM.
Will drop a line here to let you know how it goes.
Thanks for all your help!
Gary
Make sure you locate the end of the heater in the guide when inserting. If you miss the guide when it vibrates when spinning the heater will catch the spinning drum !
Hi.
Well, the new element arrived safely this AM so I set about removing the old one. What a pain in the rear that was!
Anyway, I eventually plucked it free and fitted the new one with great ease.
Just finishing off a test wash cycle and all is working perfectly... so thanks for the advice here:)
Looking at how messed up the old element was I'm definitely going to treat this new one kinder!
Again, thanks for the help!
Gary
Hi.
Gary
do you go through kettles?
Your laundry appliance definitely needs a water softener installed on the mains cold water supply. I imagine your gas engineer has fun if you have a combi.
Waste of time - not worth the expense.
Simply replace element every 2 to 5 years or however long it takes to pop - cost under a tenner.
Calgon - crazy expensive
Water softner - see above
Elements can go anyway regardless. Something that costs under a tenner isn't going to last a lifetime anyway
What about all the other components connected to water supply on the appliance ie pumps, ntcs,solenoids, jet systems ectc
Yes but most customers are not as savy so it would defs cost more than a Tenner... If a customer can afford then I would always recommend a softener, longer life for all appliances, taps & bathrooms that aren't covered in scale & scum
So enlighten me. How does a solenoid become affected by scale in a washer or dishwasher
What a load of cods wallop.
Only 3 solenoids on a washer.
1 mainwash and 1 fabsoft and 1 prewash.
All on inlet side. No scale at all. Never in my years and tears of fixing all brands have i ever replaced a scaled up solenoid valve - it just doesnt happen.
Especially now they are all cold fill only and have been for years [emoji12]
It's fact. If you worked in one of the worst areas of the country you would undoubtedly see more.
So please enlighten me again. How does scale form on a cold fill inlet solenoid
Reply to Washing Machine tripping electrics. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a...
Pritesh Patel
Hey guys, sorry if this is a daft question but ever since we've had our hotpoint washing machine the compartment on the far left (softener...
K
I bought a new washing machine, it had bad water hammer and started leaking from the inlet valve (plus a couple of other issues) so I exchanged it...
1K
Katie123
K
Had a new Kitchen fitted just before Xmas with integrated Washing Machine and Dishwasher (never again!) Appliances are located around 3.5m away...
1K
I have two Zanussi washing machines, one is a 2006 model ZWF1221G, the other, a 2013 model ZWG6141P. I can run both from the CWST or the mains...
2K
