Discuss Vented CH system constant refilling for a year in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
Bazza16
Hi all, I need some advice.....I have discovered a leak under the ground floor floorboards which to my knowledge has been going on for about a year, I understand that this means that the system would have been replenishing lost water with fresh regularly for some time, meaning that any inhibitors would have been lost some time ago, can anybody tell me the damage that would have occurred in this time period(say 1 year)
Thanks ...Bazza
Probably no more than a little corrosion. Fix the leak and dose with inhibitor.
Btw, I'd fit a filter on the return by the boiler to catch any crap on it's way back.
rust build up in your system as everything corrodes, just get it flushed through and add some inhibitor, not much else you can do
oops! thanks for your quick replies, should have mentioned that also the system is constantly pushing water through the overflow...any thoughts ?
Bazza...
Bazza...
Partial blockage where cold feed meets circulation pipe due to build up of crud. Confirm with magnet. Cut out and clean bore of pipe.
or ball valve that wont turn off
Reply to Vented CH system constant refilling for a year in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm new to the forum and just some background on myself. I have 4 years experience as a plumber but haven't worked in the trade in 15 years. I...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need...
Hi, I have a hot water cylinder which feeds 3 outlets (kitchen sink, basin in bathroom & bathtap) which has never had very good pressure (probably...
My father has a parkray fire which has a back boiler . He had a leaky radiator, when he was attempting to fix leak the circulating pump...
RobinA
R
I am looking into a new Main eco compact / Baxi 618 system boiler set up for PDHW (if its possible) I was hoping to use the EPH controls priority...
