L
laurencem
Hi, i need quite urgent help with something im not a plumber but this looks like the right place to come.
basically, i'm looking at using a vacuum insulated thermos tank for storing hot engine coolant (around 90-100 degrees c) in a motor vehicle application. the valves etc for the system will all be electronically controlled.
the issue im having is finding the best kind of valve to keep the heat insulated in the thermos tank - it will be kept there after the engine is turned off and i need to keep it as warm as possible for as long as possible. as i said im not a plumber and know nothing about valves etc but im sure there is some kind of specialised valve available?
its urgent because im due to give a presentation on this project on monday and this is the only part i havent decided on yet.
thanks
thanks
