Discuss Vaillant f75 code!!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mpedley
Ok, last week I added an extra radiator to my system.
it it had recently bee taken out of a friends house.
Since then I have had continuous problems with my vaillant ecotec 28.....
i have bled the system countless times, changed the pressure sensor, cleaned out the filter and checked the expansion tank pressure.
it will run with one radiator on but as soon as I turn the others on it crashes and shows the f75 code.
water temp is also erratic.
anything else I should try before calling out a engineer?
thanks, matt
Defo keep your hands out of the boiler - it might kill you.
Get a qualified engineer in. Don't take case off boiler in future. It's dangerous and can very easily lead to carbon monoxide poisoning.
Reply to Vaillant f75 code!!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
Hi, i've got a job with a Vaillant Ecotec 630 system boiler, and i don't know the full history but the house has definitely been extended...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need...
