Discuss Vaillant EcoTec Pro 28 Refilling Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mike Hardacre
Hi there,
When I am refilling my EcoTec Pro should I turn the left tap first or the tap or does it not matter?
Best wishes!
Thanks guys, just checking in case I did something wrong and messed up the boiler. :)
Sorry guys - just one more question. I filled the pressure up to 1.3 when cool. It's up to 2.4 bar and the heating is on. It's near the top line, but not quite there. Is this OK or have I filled it up a bit too much?
Many thanks again,
Mike.
Should be fine mike. Might as well try venting all upstairs rads which will drop it back a bit.
Many thanks again,
Mike.
If it's rising a bar from hot to cold, your vessel needs re charging. That's a GSR job.
Thanks. I don't have any upstairs radiators. I'm guessing it's still OK? I have hot water and heat and I checked a few times and it didn't move past 2.4 bar. Fingers crossed :)
Yeah she'll be fine! Leo's just on the hard sell... :army:
Just make sure next time it's serviced, your engineer checks the pressure vessel. They're prone to going flat on the later Vaillants.
Thanks for the tip Leo. It's due a service in June of this year so I'll ask the engineer about this specifically.
Ask him to change the Schrader valve before recharging, 9 times out of 10 the charge is lost through this. :)
Reply to Vaillant EcoTec Pro 28 Refilling Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
