Discuss Vaillant EcoTec Plus 837 programmer?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bluemoonstan
fitted a 837 plus and customer wanted to use his old programmer. one of those British Gas UT1. he never used the room stat. anyway left with 3 core cable at the boiler. connected live to common, S/L to RT connection on PCB and removed the 24v link. but cant get it to fire heating. got 240v at the programmer, but not at RT when call for heat. Probably something simple i missed. one of those days. Any suggestions guys??
Just typed out answer but it's in the public forum, are you GSR?
In installer mode have u got temp for ch set or is it still off? Are the valves under boiler open? Basic questions.
Click on his thingy and it just says plumbers arms , go on web view shows yellow sticker. TT app is missing a few bits.
When you say only 3 core cable, I take it you have got L N E then a supply from stat to RT so should have 4 cables into boiler.
yes ive been into installer mode and set flow temp. ive 4 core into boiler L N E from fused spur. existing 3 core cable coming from controller which ive used for switch live. if that makes sense
I would , remove bridge on ut1 so terminals 3 , 4 are volt free and normally open ( when off) run two cores from 24v , one into programmer on 3 and one in to 4 via room stat. Hey presto volt free switching . Contacts in programmer last longer
can someone tell me how i wire my hive into my ecotec 837 plus vaillant boiler ? (new model only 2 years old)
Reply to Vaillant EcoTec Plus 837 programmer?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Removing pump and installing a new pump for Vaillant ecoTEC Plus 400 15kW Heat Only Boiler. Connecting the pump to the boiler and completing all wiring for the thermostat and consumer heating controller.
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
I am considering replacing my existing boiler with the new 2023 Vaillant ecotec plus 625 boiler. I currently have 3 x Heatmiser neoStat thermostats that are all hard wired back to the wiring centre; one for the central heating, one for a room with UFH, and one for the HW. I use the Heatmiser...
I recently had a new 2023 Vaillant ecoTec plus 630 (30kW) system boiler installed along with a Low Loss Header (LLH) in my house. I have 21 rads in the house and a room with UFH. The LLH was introduced as I was finding (before the LLH was fitted) that my old boiler (Vaillant heat-only boiler)...
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also have an UFH zone in the kitchen. Near the boiler I have 2 port valves which control this part of the system. The boiler has been loosing pressure...
