Discuss Vaillant diverter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Vaillant turbo max, gets hot water only when heating is on. Am sure it's something in relation to the diverter. My question for you clever bunch, I've done very little fault finding and repair, am quite new to gas I've only really stuck to fitting boilers for a few years, but I'd like to learn about the repair. I've replaced a few diverter motors but never one with a diaphragm, is it easy? And what do I have to isolate water wise? Just cold? Or heating as well? Any advice would be great.
thanks guys.
Get yourself in the private forum.
You'll only get help there on gas sorry
Reply to Vaillant diverter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
Hi, I thought I'd share my experience of dealing with Aqualisa about their Quartz Digital Diverter. When selecting the slider rail handset the water would also constantly drip \ stream water from the overhead rain head. When selecting the rain head the pressure was very reduced and the water...
Hi, I was hoping to replace an old system boiler with a Vaillant Ecotec Exclusive 627 system boiler, thats the one with the diverter valve so no need for zone valves, controling it with a V-Smart and a VR10. I've spoken to Vaillant Tech and they said you cannot use the VR10 with a vented...
Hi I have a fully pumped heating system fitted with a Drayton MA1 diverter, after the summer run the heating stopped coming on, so I replaced the Actuator head, however I have found the actuator is stuck on H (Heating), I have turned down both heating and cylinder stat - still stuck on H. The...
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring, probably not been used until recently now it's colder. When heating is called for, the boiler fires up ok but soon shuts down the heater as the...
