Discuss Vailant TurboMax VUW 242 - No hot water, heating constantly on, water dripping from underneath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello there!
Yesterday we turned on the heating as it had been off for a while (due to the heat we've had here).
My brother went for a shower but noticed that the water wasn't hot.
We reset the boiler (Vailant Turbomax VUW 242 - 2004 install) a couple of times and the problem is still present.
I've also noticed that even though the heating is set to 'off' on the boiler and the thermostat is off, the heaters remain hot. We've also noticed droplets of water dripping from the bottom of the boiler. I've not removed the front face or had a look.
What would people say is the problem? We've rung our insurance company and they said they'll send someone out today but we'd like to know roughly the costing. :(
We've turned the boiler off as it was getting too hot due to the radiators.
Any help or advice would be greatly appreciated.
Regards,
Rik
What kind of insurance?
Oh yes, it is included. Just really worrying :(
Would it be the Diverter valve do you think?
Sorry can't say on an open forum due to anyone could try a diy repair
No worries, understood :)
The Engineer was around, had a good look and identified that it was the diverter valve and there was a fair bit of water inside on the wiring. They should be in touch tomorrow with what they're going to do.
The engineer (from the insurance company) deemed it not fixable however, we got a second opinion from a private engineer and he managed to replace the diverter valve and it's been working fine ever since!
Reply to Vailant TurboMax VUW 242 - No hot water, heating constantly on, water dripping from underneath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I've just found this forum and wondering if anyone can please help us. We've not long moved into our new home. It's has Johnson and Starley warm air heating and hot water tank in airing cupboard. All has been working fine until yesterday. We had the water softener serviced and since then...
Hi all, just moved a radiator from one wall to another, straight forward job, heating is working, problem is that on turning on a hot water tap the water coming out is heating water ( Fernox smell)and the boiler pressure drops quite quickly. Baxi Platinum 28HE. Any help or ideas please
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame to call for heat, and the receiver seems to be working ok with green light, but heating is just not firing. I really am not sure what the problem is...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I can sometimes recover the usual water pressure by turning the hot and cold water taps on and off which seems very strange to me. There is no problem...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the outputs goes to a 2 port diverter prior to the Megaflo (I believe this is some safety feature). I have run into an intermittent problem where some...
