Discuss Urgent - communal boiler in council flat - my tank doesn't fill up with hot water in the USA area at PlumbersForums.net
wish I could, only one with access to the boiler room is the plumber who refuses to return... By cylinder do you mean to water storage tank + connecting pipework? This is in a airing cupboard in our bathroom
Yes where the cylinder is
I have attached some photo's of the cylinder and surrounding pipework. Just to confirm; there is no sign of any leaks anywhere
The top pipe off the cylinder is wrong, and there’s no cylinder thermostat (unsure if there should be one on a communal feed), so no way of knowing when it needs to heat or what temperature is being stored.
thanks, it has worked like this for the last 10 years though that's what I don't understand, it just all of a sudden stopped heating up
Yep there likely to be independently controlled from the plant room
How do you control your heating and do control your hot water eg via time ?
Yea so definitely need to get access/ report it back to building maintenance
Reply to Urgent - communal boiler in council flat - my tank doesn't fill up with hot water in the USA area at PlumbersForums.net
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
Hi all, Our flat has communal heating and our thermostat is set so low so the heating should never be coming on. However over the last 10...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
