Currently reading:
Unvented Tank Hot Water Supply question
Discuss Unvented Tank Hot Water Supply question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I had my vented hot water tank replaced with an unvented tank recently.
The pipe work was altered and an expansion vessel fitted.
Is it normal for the hot supply to release the contained pressure after cold water has been heated and expanded?
This is more noticeable for example after a bath has been run and a large quantity of water has been re-heated.
This often leads to pressure relief noises coming from the tank cupboard of which I would think is the expansion vessel.
Did they fit a correctly sized expansion vessel and in the correct place? I would get a plumber who holds a current unvented qualification to have a look at it to be honest. If installed incorrectly these things can be dangerous
If what you're saying is that the water is discharging from a relief valve then no, that's no normal. And as mikes says get the original installer or another g3 qualified engineer.
No not saying from a relief valve. It seems like its doing what its supposed to by using the expansion vessel. Open hot tap and for a few seconds this extra pressure is released via expansion vessel. Just dont know if this is normal practise for one of these tanks or is there some sort of missing pressure limiting valve?
I'm not understanding what you mean by releasing pressure from he vessel.
The vessel is there to handle the expansion/contraction of the water, ou shouldn't hear anything from it.
Please phone the person who installed this, make sure he brings his ID card proving that he has got his unvented qualification. You have paid for a service and your not happy so get them back immediately. I am really reluctant to give any advice as I wouldnt want you to attempt a little bit of DIY to solve this problem, it should not be tackled by anyone who has not got the proper qualification mate imho
This is true
What kind of make on vessel is it?
Did the expansion vessel come as a package with the tank or did the installer supply that separately?
Some tanks have expansion vessels and some have an air bubble (heatrae sadia mega flow) to take the expansion
The issue may lie in how you are describing the problem, there is a difference between guessing where the noise is coming from and actually determining the source, noise has a habit of being able to travel down pipes!!
See photo for an idea of setup. All I want to know is it normal to see increased pressure from the hot tap after water has been heated. I dont know if this is normal or not. Then if it is not normal i can get someone in to take a look at the setup and sort it out. The original plumber is now retired.
Your installer didn't bother with Part L of the Building regs then ? Wonder what else he didn't know about !!!!!
need better photo showing all pipework lower down to see combined valve etc for uv cyl
flux ahoy.the black plastic thing behind the pump is a tundish. does this have water dribbling through it or is the noise from the tank. will have to be in there and listen and look..btw get a damp cloth and wipe all the pipes then with a dry cloth that green stuff will end up corroding it..how recent was this install ???
Sorry I dont follow what is wrong?
Part l is a section of the building regulations relating to the conservation of fuel. The following of these regs is mandatory and not optional.
Compliance is achieved by installing valves and controls along with insulation that meet a certain minimum requirement.
As im on my phone i can't actually view your pics to tell you exactly what is wrong. However Chris watkins who advised of this does know his stuff so i assume that one or more system controls are missing from your installation.
Is that a 3 port valve!?
Am I missing something here?
If you get big rush of water from your tap when only just open your tap and then goes down a bit this is Indication that cylinder is working ok , posible not sufficient flow of cold water to Unvented Cylinder ! I can not view pictures on my fine but I think your cold water supply is not big enough
Are we sure that the pressure vessel is connected to the hot water down service pipe?
Looking at the picture, it connects to the loreal hair product box then runs behind the cylinder (22mm pipe) then drops to low level, where does it connect into the hot water service?
Also on the pressure relief outlet, is there an open tundish lower doen with a 22mm pipe running away from that?
www.iiplumbing-services-derby.co.uk
I'm not giving any more advice on this. Think the OP should get the installation sorted properly before fiddling with it...
Reply to Unvented Tank Hot Water Supply question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
