Discuss Unrecognised elbow fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
adagio
I have a small leak from one of these elbow fittings.
https://www.dropbox.com/s/m1px3ubrgjf7vmz/IMG_1896.jpg?dl=0
Never seen one like it before and am unsure of the construction. Is there an olive under compression as in a 'normal' compression fitting joint? Can I safely try gently tightening the nut a little?
Any help gratefully received.
David
It looks similar to fittings for polyethelene pipe but slightly diff.
or an american brand like this, just guessing really sorry mate,
http://www.amazon.com/NIBCO-Series-Brass-Fitting-Solder/dp/B007Q458ZK
I dont know is my proper answer adagio soz
Tbh. It doesn't matter what make it is. Your better off cutting it out and replacing
I've used a bit of tectite and it just doesn't look like it to me.
I liked tectite though seen some demos of it and there new pipework that allows you to take it right to the boiler and was pretty impressed.
I am grateful to you all for taking the trouble to reply. I would, however, like to understand why there are screw fittings with hex nuts if the joints are push fit. I have visited the web sites of all those products mentioned and none appear to have any screw adjustment.
Probably a locking nut to prevent the fitting from accidentally releasing.
It's purely and simply a release nut. Just look at hep2o stuff, it releases the same way.
could have been an design change since first incarnation? plenty of current push fit ranges started out looking different and have been tweeked over the years.
Nobody has asked yet,
But is the O.P's installation in the U.k,, USA,, Europe or somewhere else
Good find!
Guess these'll be added to my avoid list with a lot of other push fit stuff...
Haha found it, and it is pushfit. 10 gold stars to me :)
Many thanks. Question is now how best to fix the drip which is about 2 tablespoons/day. As you can see the elbow connects to a pipe through the back of the under-sink cupboard.
Only one fix really. Cut it out and relplace.
Some form of receptacle to catch it perhaps.
Reply to Unrecognised elbow fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
