Discuss Underfloor Heating Pump goes into a blocked error (Grundfos UPM3) in the Central Heating Forum area at PlumbersForums.net
Hi all!
Went to stick the underfloor heating on and the pump started making a weird noise and the first red LED and the last amber LED are on - which per instructions means that the pump is blocked and it is necessary to deblock the shaft. It has a deblocking screw in the centre of the control box so I push it down and turned it counter-clockwise multiple times and I can hear it turning so the shaft shouldn't be blocked. But when I turn the system back on it goes into the same error mode.
I even tried to give it a a few love taps with a rubber hammer - anything else I can do, besides calling the engineer to have a look?
The pump is also a new one having been installed back in March this year, so I doubt any sludge is in the pump yet.
Worth mentioning that this is the first time we have switched the heating on for at least 5 months.
Did you love tap the screwdriver?
Need to split the pump and clean the ball
I had the same issue. I found the anti clockwise turn alone wouldn’t clear it. I isolated the flow and return, switched off the power and then tapped the screwdriver with a hammer whilst turning. I then switched it on with the flow and return still off and it started again. Then turned the flow and return on and all working.
I had the same issue. Tried turning anti clockwise multiple times but it didn’t work. Then found Jon’s advice, tried that and it worked first time. Thank you Jon!
Reply to Underfloor Heating Pump goes into a blocked error (Grundfos UPM3) in the Central Heating Forum area at PlumbersForums.net
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
1K
N
We have a weird 'dual' system in our 2 floor house we just rented out - meaning that the ground floor has an underfloor system and the top floor...
I have moved into a house which uses a Grundfos UPS 3 pump to circulate the water in a wet underfloor heating system. Last autumn the pump would...
2K
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I...
1K
Ups pump issue Fairly recently, say 12 months ago, we had a new pump fitted. It's a grundfos ups3 15- 50/65 130. (We have a small expansion tank...
1K
